Elastix system dropping calls
lumpyza
Magobaskloof - Limpopo
Hi guys,
Anyone know how i can reconfigure the lines on a elastix system, we having alot of calls being dropped and sometimes lines locking up and that just screws with the hunting line... :(
Our linux dude has just decided he's not coming in for 2 weeks now and this landed on my table!
I know the system is pretty much upto date and its running a 8 port TDM card with normal analog lines coming in.. any ideas or suggestions will be appreciated! :confused::confused::confused:
Hi guys,
I assume there are no issues with internal calls?
Convert your analogue lines to ISDN and get a Digium B410P. That or shop around for a reputable VoIP provider.
Quick fix that may or may not help if the problem is blocked ports is a daily reboot scheduled from cron.
thanks, yea internal calls are not an issue at all, will look into the B410P card... but in the meantime i will just run the daily reboot... Thanks!
