NinjaVince
- Jan 7, 2017
I have 2x traditional geysers, both having I believe a 3kw element. I currently have only one on a 'dumb' timer and I want to upgrade to have both on these smart wifi breakers that allow scheduling but also integration with Google allowing voice commands etc.
I am basically 100% on solar, with a 12kw inverter and have more than enough power throughout the day, and no issue to run both geysers on the same schedule, ie. both on between 2 and 4pm for example.
Can I have both geysers connect into one 63amp smart breaker, and is it safe?
Or do they need to be on separate 32amp smart breakers?
A quick google search shows that technically it is possible but I am not convinced it is safe or compliant.
I notice that the 63amp breakers seem to be generally cheaper than the 32amp breakers, maybe because of higher demand for 32?
Any recommendations for a good smart breaker for this purpose?
