Giarc86
- May 28, 2008
Sorry if this has been posted before, I have Googled and searched but nothings helping.
I have xubuntu on an old PC, but I cannot get the Ethernet to work. I have it connected to my router and the router light comes on and the light on the PC comes on, then i select auto etho or so, it will search a bit, but then say disconnected. The 2 other machines on the network run XP.
ifconfig:
dhclient eth0:
I know it's something to do with DHCP but no idea how to go about it.
Anyone know of a solution?
ifconfig:
ifconfig
eth0 Link encap:Ethernet HWaddr 00:00:21:c2:ff:ff
inet6 addr: fe80::200:21ff:fec2:ffff/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:7395 overruns:0 frame:14790
TX packets:0 errors:14 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:6750 (6.7 KB)
Interrupt:5 Base address:0x4800
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:10 errors:0 dropped:0 overruns:0 frame:0
TX packets:10 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:460 (460.0 B) TX bytes:460 (460.0 B)
dhclient eth0:
Listening on LPF/eth0/00:00:21:c2:ff:ff
Sending on LPF/eth0/00:00:21:c2:ff:ff
Sending on Socket/fallback
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 6
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 9
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 14
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 18
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 10
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 4
No DHCPOFFERS received.
No working leases in persistent database - sleeping.
