Excel Gurus...Please Help!
essop1@gp
Pretoria
Hi guys,
I have an excel spreadsheet with certain information on it, i go to the 'Insert Function' toolbox, select 'user defined' and select one of our in-house features, enter all necessary information then at the last enter a function and before finishing the function, at that exact same point everytime, excel crashes. Now if i enter that very same function in the particular cell without the use of the 'Insert Function' toolbox it works fine.
What could be the problem, if i do the above on another pc it works fine, only on this pc using that toolbox only. I have repaired Office, repaired windows, even used a different profile and the same result. please help. Could it be that the 'Insert Function' toolbox is corrupt?
if it is a addin it could be that it is not compatible with your version of Office
I go to the 'Insert Function' toolbox, select 'user defined' and select one of our in-house features, enter all necessary information then at the last enter a function and before finishing the function, at that exact same point everytime, excel crashes. Now if i enter that very same function in the particular cell without the use of the 'Insert Function' toolbox it works fine.
With most functions the flow is to choose it first and then enter information after.
