External Aerial Position and speed
MightyMuffinMan
Kwa-Zulu Natal
Question:
Installed the External aerial today:
I had 2 spots to choose from.
Perfect Signal: 68 Mbps but poor position for internal setup ie ends up in bedroom.
Where as I decided to have it installed in a spot with 40 Mbps so it can reach my study.
Would it be better to move it to the First Position and use wifi or set it up with the slower speed in the study?
I noticed the speed falls to 19 Mbps during Peak/Weather in the second spot.
PS: Telkom installers said I should just request re-calibration if I want it changed.
PSS to improve the speed to 68 Mbps from the same position I would have to buy a seperate wall mount bracket that can push a pole away from my wall and than request recalibration and they will come change it.
