sb 400, it is okay but there are better flashes out there for the money...with that flash you are mostly paying for the nikon name.
metz is good but it is hard to find them here in s.a.
sunpack? not really sure about that one, i have heard that you can get them here but not sure where.
have you thought about nissin? their flashes aren't bad and you can get them here.
http://www.camerastuff.co.za/shop/camera-stuff/flash-stuff/hotshoe-flashes.html
also i know that you can get sigma flashes as well and they seem to be okay flashes.
nikon flashes are amazing but they are also amazingly pricey. i know right now there are two sb 600's or 800's for sale on the outdoorphoto classifieds website so if you don't mind going second hand then check that out.
The Nikon SB600 is only around R2500 so that would be the one to get if the budget allows for it
It looks a bit too generic for my liking. I'd rather get something with a Nikon TTL module if I was you. MyWorld did some research on third party flashes recently, look for those posts.I am buying the YN-460 II speed light for R969 end of next month
All the stats and features here. http://www.alibaba.com/product-gs/274274404/New_Upgraded_YONGNUO_Flash_Speedlight_YN.html
No TTL?I am buying the YN-460 II speed light for R969 end of next month
No TTL?
I am still searching but not finding anything![]()
You're not looking hard enough - just past midway down the 2nd page in this subforum at the mo
The flash he chose is a bit outside your price range though, however, AF-assist and TTL make it a no-brainer for me.
The DF283 is cheaper, but more around the R1300 - I haven't looked at the difference between the two, but either way they look fairly decent
I see mention was made of the flash I recently purchased, and I will add a report to my initial thread, but so summarize, I'm ecstatic with my choice.
I did a wedding last week end and it turned out that this unit packs one heck of a punch for the price.
Battery life was well above expectations and cycle time was never, not even once a problem.
I would really safe up the extra R500-00 and get the Nissin, great value for money.
