Ezviz camera help
Doom5003
So i bought two EZVIZ H3 3MP 2K cameras and they both are running of a Hikvision 12 Volts 8 Channel CCTV Power Supply - DS-2FA1205-C8.
Every few days they both would go offline, at the exact same time. Now this would auto correct after a few hours, not ideal for security cameras,
Once the issue was the router, as it would for some reason stop working on the 2.4 wifi band, but a reset fixed it.
Now the other times when it happens im not at home to verify if this is the same problem, but i can verify that all the other items that require 2.4 works so i doubt that is the problem.
So anyone experiencing the same or have an idee as to what could be the problem? Could it be that the router isnt releasing new ip addresses for the cameras or that the cameras are trying to use already assigned ip addresses?
This happens has nothing to do with power/loadshedding as it happens even when the power is on and stable.
Revive
I have a EZVIZ H8C PTZ. The notifications are delayed by 60 seconds. How do I resolve this?
