Uplink
FAX OVER IP - FOIP - SOLUTION FOR WISP PROVIDERS
The FaxScan device provides a 100% reliable transmission of fax messages over the public internet by using a Store-and-Forward design (not T.37) that leverages web services.
In Short the fax scan connects to a traditional fax machine and sends faxes via the internet in stead of via a Telkom line. This solution is perfect for Wireless Isp`s (WISP), individuals and businesses that do not have access to landlines. This solution eliminates the problem with a fax to email solution in that you can send a fax from your existing fax machine without having to scan and attach documents.
You can use PC Connect - FAXSCAN on wireless networks as it does not use t.37 technology.
