Upload and share screenshots and images - print screen online | Snipboard.io
Easy and free screenshot and image sharing - upload images online with print screen and paste, or drag and drop.
This other one is the most important and it is saying unreachable but when i use vpn no issues.Hmm. It’s reachable.. what error do you get when trying to reach it?
Alright i will do just that and see if it changes.Everything points to MTU. But it doesn’t seem to be that. You changed all your interfaces back to 1500 MTU and cleared that Mangle rule right? It’s not routing either or firewalls.
Try connect your PC directly to the Vumatel CPE (might need a reboot of the CPE) and see if you see any improvement in speed and access to this site?
So i tried connecting to the ONT directly. It is the same story.
Alright thank you let me try it out. This thing is really stressing me out.This is an interesting one. Checked MTU and DNS and eliminated router.
Are you using Chrome? Check the developer console to see if any particular errors are being logged? Maybe a certain resource is being blocked. (Right click anywhere on the failed page and click on inspect). The interface is a little overwhelming- but it’s fairly easy to spot errors (they’re in red). If a resource from a different URL is failing, check to see if you can ping that url.
SO vox finally managed to fix it. It turns out you were right. it was a combination of MTU like you mentioned and i think firewall (IP) i think. They were talking about the range was too high on the MTU i think. They changed some stuff and now it is on 1480 like you mentioned earlier. Then somehow my Ip address was being blocked by a firewall. i do not know how that was possible. But they mainly changed the MTU settings like you mentioned and now all my sites are working perfectly Fine. Thank you so much. I really appreciate the help. I will also keep note of this in case i go through a problem like this again.This is an interesting one. Checked MTU and DNS and eliminated router.
