Fibre Router advice
Morte
Hi will be getting a 100/100 service in the near future and I am struggling to choose a router.
I don't need WIFI since I am using Ubiquiti APs and I will have to wired computers on the network. So a 4 port router is sufficient. I would like to be able to manage QoS etc.
I have been looking at this: https://scoop.co.za/mikrotik-rb750gr3-5-gigabit-port-soho-router.html
Is this a good option? Or should I be looking at something else? Any feedback and advice would be much appreciated.
If you have never worked on a Mikrotik then I would advise against it, better to get something with a webgui easy to manage QoS etc.
Most ISP's will give you a router which will support 4 PC's - (and will have WiFi which you can turn off if you so wish) but no need to buy something if you don't need it surely?
Agreed...
May need to buy an additional switch to connect PC's and AP's but those nowadays are cheap as chips:
I've used plenty of these and they're great
If you're looking for something a bit higher end, https://scoop.co.za/ubiquiti-edgerouterx-4-port-gigabit-router.html is a pretty good option (and fits in nicely with your Ubiquiti APs). I would probably recommend this over the Mikrotik, due to the built-in support for the fq_codel AQM, and the ability to easily configure everything through the web UI. It's also a little cheaper.
Edge router or RB750Gr3. If you are looking for rack mount, the RB2011 and RB3011 is also very good and stable solutions.
^ this. If you're not a very patient geek you will regret it. It's been 16 years since I started using mikrotik routerboards and there are still some things I can't get right ::D
Thanks for the recommendations. I'm not the most patient geek, so maybe the Mikrotik is not the best solution. Maybe sticking with Ubiquiti is a good idea.
I know most ISPs will supply me a router, but I just prefer to own mine.
Also interested in Ubiquiti routers for new fibre hookup. This one looks ideal:
https://scoop.co.za/ubiquiti-edgerouterx-5-port-gigabit-sfp-router.html
Only question is compatibility of the SFP port with Telkom/Openserve FTTH - which has literally just been cabled in. I read there are single-mode and multi-mode connections, and it's not clear to me which I have but more importantly whether this router can work with either type.
You dont use the SFP port, they will install an ONT which changes the medium from optical to electrical, so you plug in with ethernet. We have an Edgerouter X lying around if someone wants it at below cost?
I wondered about that - did quite like the neatness of having the fibre going directly into my router, but I guess if they are going to install a media converter then I may just as well use any router. My draytek ADSL router has an E-WAN port already, but I use that for my backup snowball line which I'll then lose.
Why do they have to convert it ? Why not go straight fiber to modem
Exactly why I was looking at the Ubiquiti box which has an SFP port. I know plenty about networking, but not much about physical fibre standards - except what I read about single-mode vs multi-mode fibre cable. Which gave me some concern that the SFP may not simply plug in.
Anyone using this router and specifically the SFP port with an Telkom/Openserv FFTH?
Technically that's exactly what they do... but they lock the fiber router down and make you install a second unneeded router that you have control of.
Edit: referring to openserve fibre.
Nah, that is not happening here. I'm going to be choosing an ISP that lets me use my own router kit that I manage thanks. It's only a flipping PPPoE config which is dead simple and 5 minutes to do. Not gonna use some crappy rebadged junk router just for that
