A Aardvark Well-Known Member Joined Nov 19, 2005 Messages 422 Reaction score 16 Jan 19, 2018 #1 Hi Applied to upgrade my speed from 10 megs to 100megs but webafrica say its not available. I am in the Plumstead area. Any suggestions. Thanks Johnathan
DrJohnZoidberg Honorary Master Joined Jul 24, 2006 Messages 28,315 Reaction score 7,859 Location Table View Jan 19, 2018 #2 Are you on 10Mbit fibre now and want to just upgrade to 100Mbit fibre? Who is the fibre provider?
A Aardvark Well-Known Member Joined Nov 19, 2005 Messages 422 Reaction score 16 Jan 19, 2018 #3 Yep on 10 and wanting to upgrade to 100. Openserve is the provider. I am using adjective. Johnathan
DrJohnZoidberg Honorary Master Joined Jul 24, 2006 Messages 28,315 Reaction score 7,859 Location Table View Jan 19, 2018 #4 Aardvark said: Yep on 10 and wanting to upgrade to 100. Openserve is the provider. I am using adjective. Johnathan Click to expand... Have you asked WA for a reason? Maybe https://mybroadband.co.za/vb/member.php/184018-WebAfrica-Helper can help you here.
A Aardvark Well-Known Member Joined Nov 19, 2005 Messages 422 Reaction score 16 Jan 19, 2018 #5 They say that the openserve system says it's not available.
