What he said.Unfortunately you can not dial pppoe from different ISPs on Vumatel. Vumatel configures the vlan for each ISP and then that is the ISP the network is provisioned for.
Pretty much depending on your terms with your current ISP.Ok so no testing.
How do I go about switching to a different ISP should I not be satisfied with my current ISP?
Is it as simple as cancelling with my current ISP and signing up with a new one?
Or how does it work?
Hi there, hope you are well.Any test accounts available @PBCool ?
