I want my citi golf to use less fuel will this http://www.bidorbuy.co.za/item/16689952/SUPER_MAGNETIC_FUEL_SAVER_FOR_ALL_VEHICLES.html help
if not what will?
if not what will?
I agree! And the equipment on that link basically looks like two magnets over the fuel line...![]()
OK what tuning can i do to the car then?
Yes, make sure that it has a clean tummy full of oil, a new set of spark plugs, if it's older change points and condenser, then set the carb to run as lean as you can without burning valves...if it is fuel injected, make sure that the CO levels are correct...new oil and air filters...then, make sure your tyres are pumped correctly, and don't drive like a Cretin, and you will have saved the R100 that crook was going to swipe from you by selling his con machine!![]()
don't ride on your clutch when stopping on an uphill, etc, etc
if not what will?
