fx 5500 problems please help
labratza
Kempies at the moment
Hi
one of my clients bought fx5500 from us and now there is a problem
when he pops the card into the computer it will not go into windows it just keeps restarting but as soon as he takes the card out it works perfectly
any one have any kind of idea what the problem could be
Regards
Eon
Probably a driver problem, try restart in VGA mode, remove the old drivers and reboot to install the new ones....
take the card out and boot into safe mode (if you are unable to boot in to vga mode like conradl said) then uninstall the old or onboard gpu's driver. Shutdown the pc and insert the new card. It should boot into windows now.
