So I removed the memory card, wiped the phone and charged it to 100%. I am on 3G, brightness is less than a half and nothing except battery saving mode and mobile data is on. Is the usage good or bad? Screen on time is also 16min
Did you get 9 hours with 8% battery usage?
Looks like overnight with no usage. We need to see what happens on an average day.
I see in another thread the dude had someting corrupt on his SD card and it screwed up his phone's battery life.
Did you format your SD card before you inserted it into your S3?
Also check which accounts are syncing. If you're using Facebook, disable all syncing! FB chows any battery flat in no time.
Nope I put it directly in. No formatting. I did remove it now and I formatted the phone so I will see what happenes today. I am currently on 82% with 1H of screen on time
Not bad at all!
Seems like a huge improvement since I have removed the memory card. Wil post the usage of the whole day tonight.
The problem is now you don't have all your media to listen to, and your usage pattern is most likely gonna be different, and not a true reflection.
If you MAKE it through the whole day.![]()
Screen on time is 1H 20min. Can anyone tell me if this is good?
It's exellent!
It means you will get almost/close to six hours screen on time, which is very good for a 2000 mAh battery and a 4.8'' display.
