Geyser timer solution for solar
Even at 55.2V?
Yes. Only under certain conditions. Let's say the battery is at 96% as per bms SOC and I draw something heavy and it drains and then switches back to charging at 100% it gets that OVP warning.
If there is no load on the battery and it charges normally then at that voltage it seems to cut out at around 89% SOC and just stays there. It doesn't go higher.
At 55.6 which it is now it does go to 100% eventually
Can you set absorption time on inverter? I would take SOC counter readings with bag of salt.
It probably resets to 100% when cell 5 hits OVP.
I hit that alarm 4 days ago but it's probably just because now I have the geyser on and the poor pv last few days so I'm not getting to 100% fast.
Why does it use all different watts?
As far as i have it some solar geyser setups uses 3 panels with an mppt basicly running element directly from the panels ie no inverting to 220v ac
The wattage then depends on solar output as clouds roll over or angle changes wattage changes
Having a charge voltage that is lower the amps will drop off and take longer to get full as long as it still accept charge 1A or more the bms will keep balancing
On many they only balalance while charging and only when cell voltage pops over 3.45v
Tha battery spends verry little time there normally
Looks like his charge voltage is 57.6V.
They don’t push from the panel straight to the element otherwise it won’t meet certification for the thermostat.
Some do PWM, others a modulated wave.
