I am very new to Windows Domains and Group Policies etc, and I'm having some trouble with trying to implement a few things.
Basically, I want our users at the JHB office to authenticate over our VPN on the server in Durban.
So I did the following to test out the idea:
I create a new Organizational Unit
I right click the OU and tick "Block Inheritance" (so that it ignores the default GPO)
I then create and link a new Group Policy Object to that OU called Test GPO
For testing purposes, I edit the GPO and go to User Configuration -> Control Panel -> Add or Remove Programs and I enable "Remove Add or Remove Programs"
I then create a new user called Test User and place it in the newly created OU
I walk over to any PC in the office that is on the domain and log in with Test User's credentials on the domain
It logs me in and creates a new local profile
I then go to Control Panel to see if the new GPO has taken effect.
It has not. Add or Remove Programs is still there.
What gives? Why is it not applying my GPO?
