Hard drive advice - Sasmsung spinpoint 1tb
Hemps
Slummies
I need a new 1tb hard drive as my seagate 1 tb started clicking:
Needless to say - I'll never go for seagate again - that's drive number 7 that we have had go down - different locations as well.
Was looking at Samsung spin-point 1tb for R752
Western digital is R234 more expensive.
Looking for a drive with little power consumption and reliable.
For R752 thats not bad - sending the seagate back to Rectron for replacement yet again, what's up with Seagate nowadays?
I have had a 500gb, 750gb and now a terrabit drive all crash!!
I still have pre 500gb western digitals running like forever without hassles?
Western Digital is the one to get.....you get what you pay for.
Can't blame Seagate... I have like... 8, none give me problems, however, I expect one to go, it's a mechanical device... it happens.
All brands have failures, it's just reality for mechanical devices. I swore by Seagate even after I lost a 160Gb 2 years ago. After the 7200.11 firmware disaster, I got a 1TB Samsung F1 and then a few months later got a 1TB Seagate 7200.12. Both are still working fine (touch wood!)
Western Digital FTW - no issues with any of mine - they are really solid drives.
I gave up on my Samsung 1TB's after my 5th return of two new drives - replaced them with WD's...
What version is it? 7200.11 or 7200.12?
Samsung 1TBs are solid, run cool too!
Doesn't say on website
Capacity 1TB
Interface Serial ATA 3.0Gbps
Buffer DRAM Size 32MB
Byte per Sector 512 bytes
Rotational Speed 7,200RPM
Performance Specifications Average Latency 4.17ms
Average Seek time(typical) Track to track 8.9ms
Media Transfer Rate(Max.) Buffer to/from Host (Max) 300MB/sec
Media to/from Buffer (Min/Max) 175MB/sec
Drive Reday Time(typical) 12sec
Reliability Specifications Non-recoverable Read Error 1 sector in 10 ~ 15 bits
Start/Stop Cycles 50,000
Acoustics Idle 2.7Bel
Performance Seek 2.9Bel
Environmental Specifications Temperature Operating 0 ~ 60 °C
Non-operating -40 ~ 70 °C
Humidity(non-condensing) Operating 5 ~ 90%
Non-operationg 5 ~ 95%
Linear Shock(1/2 sine pulse) Operating 70G
Non-operating 300G
Altitude(relative to sea level) Operating -300 to 3,000m
Non-operating -300 to 12,000m
Power Requirenents Voltage +5V ± 5%, +12V ± 10%
Spin-up Current(Max.) 2.4A
Seek(typical) 7.6W
Read/Write(typical) 8.4W
Idle(typical) 6.7W
Standby(typical) 0.7/1W
Sleep(typical) 0.7/1W
Physical Dimension Height (Max.) 26.1mm
Width 101.5mm
Length 147.0mm
Weight(avg.) 650g
I got both a seagate and a samsung.. both running just great.. had a burn-out on the seagate but their warranty is outstanding, replaced in 2 weeks no questions asked so they are still champs in my eyes.
