Hi, it seems I should not go away from my HD decoder for more than a week or it breaks down. This time the Dolby Surround stopped working. I just get short snippets of sound coming through. Same story for old recordings that I know worked fine before.
I tested cables and the port on the amp, all working fine. Restarted, reset to factory defaults and reloaded updated software manually from front panel, no change. I even spend the required useless 30min on the phone with Monochoice.
So here I am again, if no one has any advice, it's back to the service centre and goodbye to all the recordings on the decoder AGAIN!
It seems the mean time between failure for the HD PVR is about 3-4 months, this will be my 3rd one since Dec 08.
Any advice?
Thanks.
Deon
Any advice?
Thanks.
Deon
