HDPVR 4tuner question
Heisenborg
Hi
I recently moved my HDPVR 4tuner to another room and for some reason it no longer records future scheduled things. Could this be a faulty cable on my end?
What should i be seeing in the tuner strength screen for each of the 4 tuners?
Thx
are you trying to record series?
I've noticed recently that when I set up recurring record of a series for some reason it doesn't and I have to delete the request and set it up again usually when an episode of the series is running, it only started a couple of months ago after I assume another software upgrade
No wasnt a recurring series issue. Any random thing i try to record just doesnt record
Hi
Thx
Try watching on like Mnet and try recording on Discovery and maybe cartoon network same time and see if one of them goes out
Signal Strength and Quality should ideally be 95% and higher on all 4 tuners.
Tuner 2 & 3 are for recordings, check those cables
Those tuners will only show signal though when a recording is in progress
Try swapping tuner 1 & 2 around, if you suddenly dont get a picture then there is a problem with that cable
I just tried recording 2 shows and tuner 2 was showing 0%. Im guessing the cable isnt right
Turned out to be a faulty cable on tuner2, thx for the help!
