Headphone extension cable
Alan
Looking for extension cable for a pair of Sennheiser headphones. I got a 1.6meter cable with them but would prefer something a bit longer. Seems rather difficult to locate.
3.5MM?
Go to PnP and buy the normal Ellies extension cable.
It's about R30 for 5m.
You will need to buy the small male to female jack as well.
Or go to Builders.
Zakspeed should have, though I don't really like buying from them...I dunno, I always think their stuff is inferior even though it's probably perfectly fine. Music shops should also stock - Marshall Music or Bothners. Give 'em a call and see if they stock.
Believe it or not, I was phoning around today to buy the exact same product (1M both male and female 3.5MM Jacks). I phoned (redacted*) and they said they have ONE in stock, all be going there this week to buy it.
* You aint getting my extention cable. Ill PM you were I got it once I bought it.
I bought mine @ Dions Wired. Just a normal Ellies brand I think it was.
staff at Dions Wired said I should rather get a quality brand as cheaper brands would negatively affect the quality of the audio.
Staff at Dion Wired is trying to make more commission. Unless it's super cheap Chinese flea market crap you won't notice.
They didn't stock the cables and advised me to go somewhere that did. but yeah probably won't notice if I went with average extension cables
Got a 4,5m one from Zakspeed for R30 also to use it with my Sennheiser's. Works fine, no problems.
Another thread necro, my second this week, I must be good at this.
Just received my Monster DNA headphones, but the cable with the inline mic is way too short for me to use at my PC.
So, I would like to know if these are available with inline mics? The one without the inline mic is long enough I think, but I need the mic obviously.
Just realised my post sounds retarded, and this thread is not about the same thing as what I'm looking for, but it will work for what I need.
Ignore my post lol.
Move your PC... Duh!
:p
