Hello how get an openserve B number using my serial number ?
My serial no is 4857544327113D9E
Telkom need the B to activate my fibre line
The technician didn't write it the ONT when he did the installation
The line should be active already when Openserve technician leaves the property.
The B number should not be required to activate but Telkom would be able to obtain the B number from the order they have
The line is not activated my ONT Los light has been flash red since two weeks ago when the technician did the installation.The line should be active already when Openserve technician leaves the property.
The B number should not be required to activate but Telkom would be able to obtain the B number from the order they have placed.
My fibre line was installed 20 days ago. The Los light is flashing red on the ONT since installation. However the technician didn't bring the Wi-Fi router. My question is do you need Wi-Fi router to be connected on the ONT for the Los to disappear or for the fibre line to be active
My fibre line was installed 20 days ago. The Los light is flashing red on the ONT since installation. However the technician didn't bring the Wi-Fi router. My question is do you need Wi-Fi router to be connected on the ONT for the Los to disappear or for the fibre line to be activeThat should not be the case at all. This could mean that the installation is incomplete and Telkom would need to log a fault with Openserve to assist with the incomplete installation order.
Enjoy your compulsory netflix subscription.Telkom need the B to activate my fibre line
