I connected it the same way as the lead acid was connected, red wire to red, black to black. It's coming from the battery, and every now and then it will stop and then start again.Either sound is not good. Check the terminals of your battery and that the connectors are on tight and not arcing. If the noise is coming from the battery itself, then you could possibly have a chemistry issue, in that case I'd disconnect and immediately do a RMA as its dangerous.
