phly
- Mar 13, 2013
Veterans and gurus alike. With a budget of say 6k - 6.5k ZAR, what decent laptop can I manage to wrangle up in these touch times?
The use case is just standard use, surfing the net, light document work. Nothing too hectic. Not even gaming. Focus is bang for the buck or value for the budget. Speed of the laptop and battery life are perhaps the only major tick boxes.
I've only managed to spot the following two that fit within the budget:
An Asus AMD laptop: https://www.takealot.com/asus-laptop-15-m509-amd-a9-8gb-512gb-15-6-notebook-slate-grey/PLID69240238 (Price seems to have gone up overnite)
And an Intel Asus: https://www.incredible.co.za/asus-x543-core-i3-notebook-1 - which coincidentally also went up with 500 bucks since the weekend.
Any others I should consider? Or which of the above should I opt for over the other?
