Help , DSL problem
Vahooli
hi, anyone can help me ?
my dsl have a problem and nobody can solve it! i have slow speed with alot of disconnection !
a maintaince come in my home but cant solve it !and telephone center cant solve it too !
i think i have a good SNR and Line Attenuation but i dont know why alot of disconnection ! i use this line just for dsl.
and i should i say my dsl havnt anyproblem between ~12am -~12pm.
see my detail when my connection is stablished :
Update Counter : 13783
Modulation : ADSL2
Annex Mode : Annex A/L
Line State : up
Lan Tx : 1666595
Lan Rx : 661447
ADSL Tx : 2679
ADSL Rx : 3295
CRC Down : 0
CRC Up : 0
FEC Down : 0
FEC Up : 1934
HEC Down : 0
HEC Up : 0
SNR Up : 23.0
SNR Down : 27.5
Line Attenuation Up : 12.0
Line Attenuation Down : 25.0
Data Rate Up : 256
Data Rate Down : 1024
is there anywrong with FEC ? during night just 32 for 11hours but now after stablished after 12pm go up rapidly . plz help me :(
Your line is perfect, if you have problems then it is due to exchange congestion.
yeah my line is great ! but alot of time i havnt link and alot of disconnection .. for example now i havnt link !! what should i do :(?
If you can, try a different modem/router. If the line is fine, it could well be that. I've seen a few ZyXEL routers with similar problems.
my modem is ASUS N10
now it connect after some hours :
Update Counter : 152
Modulation : ADSL2
Line State : up
Lan Tx : 1778249
Lan Rx : 695252
ADSL Tx : 1928
ADSL Rx : 2614
CRC Down : 0
CRC Up : 383
FEC Down : 0
FEC Up : 4532
HEC Down : 2529
HEC Up : 0
SNR Up : 28.5
SNR Down : 31.9
Line Attenuation Up : 12.2
Data Rate Up : 252
see CRC FEC HEC...
my FEC HES CRC go up ... why ? whts them exactly ? how can i reduce them ?
Try a different modem, post your stats then.... It's strange that ur upload isn't 512kb
i dont think its reason for my problem ...
Vahooli, where exactly are you? Your location may help with diagnosing your problem.
from Iran ... isp said we dont know whts problem and telephone center said it too .. they say all things are right...
If you use the line just for DSL
Take every thing off the line (telephone and filter ) leave only the modem,make sure only the modem is connected.
If the fault is still there then you have a problems with your line.
Try to borrow a modem from some one to test if the problem gets better.
Might be an issue with your telephone line.
What's the call quality like when making calls on your landline, after isolating a telephone handset?
call is good ... i dont know whats happen to me :( see my general log in 1 hour :
Aug 11 14:27:43 pppd[419]: PPP session is 23118 (0x5a4e)
Aug 11 14:27:43 pppd[419]: Connected to 00:30:88:1a:4e:59 via interface eth2.2.1
Aug 11 14:27:43 pppd[419]: Using interface ppp0
Aug 11 14:27:43 pppd[419]: Connect: ppp0 <--> eth2.2.1
Aug 11 14:27:46 WAN Connection: The cable for Ethernet was not plugged in.
Aug 11 14:28:13 pppd[419]: No response to PAP authenticate-requests
Aug 11 14:28:19 pppd[419]: Connection terminated.
Aug 11 14:28:19 pppd[419]: Sent PADT
Aug 11 14:28:19 pppd[419]: Modem hangup
Aug 11 14:28:25 WAN Connection: PPPoE or PPTP authentification failed.
Aug 11 14:28:30 pppd[419]: PPP session is 7932 (0x1efc)
Aug 11 14:28:30 pppd[419]: Connected to 00:30:88:1a:4e:59 via interface eth2.2.1
Aug 11 14:28:30 pppd[419]: Using interface ppp0
Aug 11 14:28:30 pppd[419]: Connect: ppp0 <--> eth2.2.1
Aug 11 14:28:31 pppd[419]: PAP authentication succeeded
Aug 11 14:28:31 pppd[419]: peer from calling number 00:30:88:1A:4E:59 authorized
Aug 11 14:28:31 DSL-N10: auth-up starts
Aug 11 14:28:31 pppd[419]: local IP address 91.99.44.142
Aug 11 14:28:31 pppd[419]: remote IP address 91.99.0.1
Aug 11 14:28:31 pppd[419]: primary DNS address 213.217.60.172
Aug 11 14:28:31 pppd[419]: secondary DNS address 213.217.60.170
Aug 11 14:28:31 DSL-N10: ip-up starts
Aug 11 14:28:31 dnsmasq[314]: read /etc/hosts – 3 addresses
Aug 11 14:28:31 dnsmasq[314]: using nameserver 213.217.60.170#53
Aug 11 14:28:31 dnsmasq[314]: using nameserver 213.217.60.172#53
Aug 11 14:28:32 WAN Connection: WAN was restored.
Aug 11 14:28:43 PPPoE: connect to ISP
Aug 11 14:28:43 DSL-N10: ntp starts
Aug 11 14:44:17 ntp client: time is synchronized to time.nist.gov pool.ntp.org
Aug 11 14:57:40 WAN Connection: The cable for Ethernet was not plugged in.
Aug 11 14:58:38 pppd[419]: No response to 10 echo-requests
Aug 11 14:58:38 pppd[419]: Serial link appears to be disconnected.
Aug 11 14:58:38 pppd[419]: Connect time 30.2 minutes.
Aug 11 14:58:38 pppd[419]: Sent 3376 bytes, received 6667 bytes.
Aug 11 14:58:38 DSL-N10: auth-down starts
Aug 11 14:58:38 DSL-N10: ip-down starts
Aug 11 14:58:38 dnsmasq[314]: read /etc/hosts – 3 addresses
Aug 11 14:58:38 dnsmasq[314]: using nameserver 213.217.60.170#53
Aug 11 14:58:38 dnsmasq[314]: using nameserver 213.217.60.172#53
Aug 11 14:58:38 PPPoE: Disconnected
Aug 11 14:58:44 pppd[419]: Connection terminated.
Aug 11 14:58:44 pppd[419]: Sent PADT
Aug 11 14:58:44 pppd[419]: Modem hangup
Aug 11 14:58:52 WAN Connection: No response from the remote server.
Aug 11 14:59:29 pppd[419]: Timeout waiting for PADS packets
Aug 11 14:59:29 pppd[419]: Unable to complete PPPoE Discovery
Aug 11 14:59:40 pppd[419]: PPP session is 18865 (0x49b1)
Aug 11 14:59:40 pppd[419]: Connected to 00:30:88:1a:4e:59 via interface eth2.2.1
Aug 11 14:59:40 pppd[419]: Using interface ppp0
Aug 11 14:59:40 pppd[419]: Connect: ppp0 <--> eth2.2.1
Aug 11 14:59:41 pppd[419]: PAP authentication succeeded
Aug 11 14:59:41 pppd[419]: peer from calling number 00:30:88:1A:4E:59 authorized
Aug 11 14:59:41 DSL-N10: auth-up starts
Aug 11 14:59:41 pppd[419]: local IP address 91.99.6.79
Aug 11 14:59:41 pppd[419]: remote IP address 91.99.0.1
Aug 11 14:59:41 pppd[419]: primary DNS address 213.217.60.172
Aug 11 14:59:41 pppd[419]: secondary DNS address 213.217.60.170
Aug 11 14:59:41 DSL-N10: ip-up starts
Aug 11 14:59:41 dnsmasq[314]: read /etc/hosts – 3 addresses
Aug 11 14:59:41 dnsmasq[314]: using nameserver 213.217.60.170#53
Aug 11 14:59:41 dnsmasq[314]: using nameserver 213.217.60.172#53
Aug 11 14:59:41 WAN Connection: WAN was restored.
Aug 11 14:59:54 DSL-N10: ntp starts
Aug 11 14:59:54 PPPoE: connect to ISP
Aug 11 15:22:43 WAN Connection: The cable for Ethernet was not plugged in.
Aug 11 15:23:41 pppd[419]: No response to 10 echo-requests
Aug 11 15:23:41 pppd[419]: Serial link appears to be disconnected.
Aug 11 15:23:41 pppd[419]: Connect time 24.0 minutes.
Aug 11 15:23:41 pppd[419]: Sent 73541 bytes, received 259874 bytes.
Aug 11 15:23:41 DSL-N10: auth-down starts
Aug 11 15:23:41 DSL-N10: ip-down starts
Aug 11 15:23:41 dnsmasq[314]: read /etc/hosts – 3 addresses
Aug 11 15:23:41 dnsmasq[314]: using nameserver 213.217.60.170#53
Aug 11 15:23:41 dnsmasq[314]: using nameserver 213.217.60.172#53
Aug 11 15:23:41 PPPoE: Disconnected
Aug 11 15:23:47 pppd[419]: Connection terminated.
Aug 11 15:23:47 pppd[419]: Sent PADT
Aug 11 15:23:47 pppd[419]: Modem hangup
Aug 11 15:24:32 pppd[419]: Timeout waiting for PADO packets
Aug 11 15:24:32 pppd[419]: Unable to complete PPPoE Discovery
Aug 11 15:25:17 pppd[419]: Timeout waiting for PADO packets
Aug 11 15:25:17 pppd[419]: Unable to complete PPPoE Discovery
Aug 11 15:26:02 pppd[419]: Timeout waiting for PADO packets
Aug 11 15:26:02 pppd[419]: Unable to complete PPPoE Discovery
Aug 11 15:26:47 pppd[419]: Timeout waiting for PADO packets
Aug 11 15:26:47 pppd[419]: Unable to complete PPPoE Discovery
Aug 11 15:27:07 WAN Connection: No response from the remote server.
Aug 11 15:27:16 WAN Connection: The cable for Ethernet was not plugged in.
Aug 11 15:27:32 pppd[419]: Timeout waiting for PADO packets
Aug 11 15:27:32 pppd[419]: Unable to complete PPPoE Discovery
Aug 11 15:28:17 pppd[419]: Timeout waiting for PADO packets
Aug 11 15:28:17 pppd[419]: Unable to complete PPPoE Discovery
Aug 11 15:29:02 pppd[419]: Timeout waiting for PADO packets
Aug 11 15:29:02 pppd[419]: Unable to complete PPPoE Discovery
Aug 11 15:29:46 WAN Connection: No response from the remote server.
Aug 11 15:29:48 pppd[419]: Timeout waiting for PADO packets
Aug 11 15:29:48 pppd[419]: Unable to complete PPPoE Discovery
Aug 11 15:29:57 WAN Connection: The cable for Ethernet was not plugged in.
Aug 11 15:30:33 pppd[419]: Timeout waiting for PADO packets
Aug 11 15:30:33 pppd[419]: Unable to complete PPPoE Discovery
Aug 11 15:31:18 pppd[419]: Timeout waiting for PADO packets
Aug 11 15:31:18 pppd[419]: Unable to complete PPPoE Discovery
Aug 11 15:31:25 WAN Connection: No response from the remote server.
Aug 11 15:31:28 pppd[419]: PPP session is 8413 (0x20dd)
Aug 11 15:31:28 pppd[419]: Connected to 00:30:88:1a:4e:59 via interface eth2.2.1
Aug 11 15:31:28 pppd[419]: Using interface ppp0
Aug 11 15:31:28 pppd[419]: Connect: ppp0 <--> eth2.2.1
Aug 11 15:31:29 pppd[419]: PAP authentication succeeded
Aug 11 15:31:29 pppd[419]: peer from calling number 00:30:88:1A:4E:59 authorized
Aug 11 15:31:29 DSL-N10: auth-up starts
Aug 11 15:31:29 pppd[419]: local IP address 188.245.207.155
Aug 11 15:31:29 pppd[419]: remote IP address 91.99.0.1
Aug 11 15:31:29 pppd[419]: primary DNS address 213.217.60.172
Aug 11 15:31:29 pppd[419]: secondary DNS address 213.217.60.170
Aug 11 15:31:29 DSL-N10: ip-up starts
Aug 11 15:31:29 WAN Connection: WAN was restored.
Aug 11 15:31:29 dnsmasq[314]: read /etc/hosts – 3 addresses
Aug 11 15:31:29 dnsmasq[314]: using nameserver 213.217.60.170#53
Aug 11 15:31:29 dnsmasq[314]: using nameserver 213.217.60.172#53
Aug 11 15:31:54 DSL-N10: ntp starts
Aug 11 15:31:54 PPPoE: connect to ISP
