Help identifying a Vumatel trenched cpe/ont
Jeasson
Would just like make and model.
Thank you
Previous models were Raycores. What do you need make and model for?
It giving me abit of a problem. And see what the indicator light means.
The power light has been flashing and the fibre and lan light are orange which is a completely different behavior than normal.
No worries, what is the problem?
Orange is typically 1Gbps on the lan, green means 100Mbps.
Asked my ISP it seems my IP lease has ended,which was causing my issues.
And thanks go the info about colors for the light
