Help me with a connection.
CrzWaco
Pretoria
So I just brought a local only package from openweb and now want to use it.
I created a new pppoe(dailup) connection and it connects but when I go and check if I have a session in the control panel of IS it does not show it. So I think its not working but can't be sure.
What I have done set the dns servers manualy on my lan and not using the one supplied. Change the settings of the connection manualy so that everything is correct Ip adress dns servers.Firewall is off on this connection.
But nothing.Just checked my statistics again and it showed I was online sometime for half an hour but have no idea when probably yesterday trying to set it up.But then the weird thing is I could still access international sites.
I have a axxess local only and can easily connect using the pppoe(dailup) connection.
http://support.microsoft.com/kb/283070
So what I am I missing?
I know that one is IS and the other one saix but can that really make this kind of difference?
Running 4 pc on the router/lan
Router Mega105wr
Mode : Router not bridge
I am still trying to find the password for my connection so that I can change it to bridge.
are you using both connections at the same time? If yes then the router must be set in bridge mode.
