Help needed with 8ta
boostergold
Hi there I'm sorry to bother I need help with my 8ta ten gig I have been using my samsung jet as a modem and connecting through samsung pc suite now my baby daughter deleted the connection in pc suite I have tried to redo it from memory buy all I get is to the registering computer to network but it won't go. Can some one help me and tell me how to set the connection again I use my internet for work so I'm a tad knackered here
After setting up the connection you need to add this:
Start > Control Panel > Phone & Modems > Modems > Properties > Advanced
Then enter:
at+cgdcont=1,"IP","internet"
select OK.
If options are greyed out, click General > Change settings
But how do I set up the connection. I need the apn and phone number as well I know I suck
Thanks will try at the office It gets stuck at registering the pc on the network
Wait I gave wrong info its samsung pc studio I want to connect with my samsung as the modem I have been able to do it before but now she deleted the profile for my connections and I can't remember how I set it up.
I did yes I phoned 8ta and I have to say the guy was amazing he not only walked me through he was friendly and helped me get connected away from the samsung pc studio. Had to set up a dial connection and work that way round but I have internet again at least
Glad you were helped :)
Regards,
Social Media Team
