HELP Please - USB 3.0 Conundrum
Finhobbyist
RSA
Hi all you tech wizzzz-izzzs :)
I have a home desktop PC with only two USB3.0 ports at the back. The PC is mounted under a desk, so I need an extension USB3.0 cable to be able to make use of the high speeds with my USB3.0 HDD etc.
I have gone through three cables already that always fail after the 12month warranty has passed; and we all know that Takealot etc then just dont care, even if the cable was hardly used at home.
Any advice on a quality USB3.0 cable thats available locally that will last.
Thanks so much!
