help please
acetheking
hi guys got a problem i whant to get 2 pc on 1 adsl router 5100 telkom but cant get into my router and dont know the user and paswoord for the router
want to use 2 difrent user and paswword for diffrent accounts one telkom and the other is webonline:confused:
Reset the router, look in your manual for the default password. Set the router to Bridged mode, create a Broadband dialup connection on each pc ;)
help
The router should have a reset button at the back, use a pen or sharp object and keep it pressed in for about 20 seconds, don't press too hard, but make sure it resets. I hope you know the ISP username and passwords.
The username and password for the router is admin admin (username: admin, password: admin) Try these first before resetting the router.
Here's the manual:http://www.telkom.co.za/pls/portal/...s/dsl/docs/Telkom ADSL5100QuickStartGuide.pdf
teraside
can you help me this is my first time doing this and i dont know waht to do
ok
teraside
sorry to be so stupid about this and i rely do thank you for your help
and i really feel stupid but what must i do know
teraside
I asked you to be patient and not to double post, that's a start dude.
I don't know your router configuration, you need to look through your router configuration for the place where your username and password is saved, then you have set the connection to "Bridge" mode and save the setting to your router, then you create a dialup connection in windows on each pc and connect with the username and password.
Read dear man, read and look.
teraside
teraside
ok if got this on my router when i log in hope it helps
Advance setup
# paswoord
# Lan
# Wan
# Security
# Dynamic DNS
# Time Zone
# Remote management
# UPnP
It helps, thank you.
Click WAN and look for an Option which says Bridge or Bridge mode, select it and save the settings to the router, look for an option which says save settings or save to flash.
