Help please
marine1
A black hole in the universe - JHB
Hey guys need some help please.
I have the following file:
I am trying to play it on my IAMM NTD 38 but no sound comes out on this particular file.
What could I do to fix this?
Re encode the audio? Which program?
I am assuming its the DTS issue and maybe AC3 would be better?
Thanks here are the file specs:
Format : Matroska
File size : 4.37 GiB
Duration : 1h 38mn
Overall bit rate : 6 340 Kbps
Encoded date : UTC 2008-06-18 00:08:36
Writing application : mkvmerge v2.2.0 ('Turn It On Again') built on Mar 4 2008 12:58:26
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Muxing mode : Container [email protected]
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 38mn
Bit rate : 5 459 Kbps
Nominal bit rate : 5 581 Kbps
Width : 1 280 pixels
Height : 532 pixels
Display aspect ratio : 2.40:1
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.334
Stream size : 3.75 GiB (86%)
Title : x264 @ 5581kbps
Writing library : x264 core 59 r859M ce13bb6
Encoding settings : cabac=1 / ref=5 / deblock=1:-3:-3 /
Audio
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 1h 38mn
Bit rate mode : Constant
Bit rate : 755 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
Stream size : 532 MiB (12%)
Title : DTS 5.1 @ 768kbps
Language : English
Text
Format : ASS
Codec ID : S_TEXT/ASS
Codec ID/Info : Advanced Sub Station Alpha
Language : English
