I wish to migrate from the old SD PVR 1 with Xtraview, to two
Explora 2's in two different rooms. Each planned as 1 view and
1 record. The system currently has a dual LNB.
1. Which installation layout is advised. I see some with a cable
switch, while the smart LNB is also an option.
2. Is a smart card required for the second Explora 2, or does
the second unit "see" the subscription through the switch or
smart LNB?
3. Is any config required to set up, other than the user band
1-2-3 frequencies ?
Thank you.
smart LNB?
1-2-3 frequencies ?
Thank you.
