help with my 3g huawei
wakka wakka
every time i try connect it goes tells me that there's an error, and a connection could not be established. it says"A connection to the remote computer could not be established, so the port used for this connection was closed ". it then tells me to search for the error number provided, but no error number is given. this started about a week ago, out of nowhere.
does anyone know whats going on?
thanks
thanks
Have you got money on your sim?
I had the same problem.
Unplug.
Go to control panel.
Add and remove.
Remove s/ware.
Re-install.
tries uninstalling, didnt work.
i'll try get more money on my phone tommorow, do u think this will make a difference?
thanks for responses thus far.
huawei ec500 problem
hello folks
i have the same problem
since two or three weeks i am discovering the unability to connect with my huawei modem
we are using three people the same modem and the problem persist only on my computer (win xp proff)
i tryied to reinstall hundrets of times in several ways and without success
i am not really in the mood of reinstalling the OS
ps: i did cleaned the registry as well
error: message ->>>
"A connection to the remote computer could not be established. You might need to change the network settings for this connection. For further assistance, click More info or search Help and Support Center for this error number"
unfortunately there is no error number provided and i did tryied to search for support on their forums = no success
hello folks
error: message ->>>
Start ->> Connect to ->> VMCLite ->> Provide the error number given
ec500
maybe i did not understood your answer
what is VMCLite?
if it is a additional software
please provide link for download
2 things firstly this happens from time to time with the device and the way to fix is do a complete un-install the restart and do re-install,it can take up to 3 tries at time but it will work,in my opinion i think this problem is driver authentication related.
