Help with PPPoE/Ethernet
henkrossouw
Sentech says MyWireless will work with Mac, (I have OS X 10.2.6) but offer no support.
Won't work with USB, so I bought Ethernet cable. I keep getting the error: "Could not connect to remote PPP server. Check settings and try again."
My username and password for PPPoE is definitely correct.
- Does keeping the MTU to 576 instead of Ethernet standard of 1400 apply, because using Ethernet?
- Is there anything else obvious? Sentech's FAQs state that using an Ethernet cable requires "manual configuration of PPPoE" and additional routing." But I can't get any joy out of the helpdesk about what that means. They referred me here.
Help?
The connection status indicator light *flashing* green means the link is up and I just can't connect, right?
