Spartaniz
ok so i've did follow instructions on how to setup route sentry on vista and both account can connect at the same time and route sentry does connect, but when i test to see if it works then it doesnt use local account....
i'mnot sure if im setting up route sentry correctly and i'm not sure how to use the updated localroutes.dat update?
both my local and international IP's are the same and as you guys said, then its not working...
