HavocXphere
Update: Seems stable now. Maybe just a fluke. Please ignore thread unless I change this header. Thanks all.
Noobs might still want to have a look at it just to see how ADSL help request are done properly though.
Evening people
Generally I don't need help with ADSL, but today I do. I've got a bit of a conundrum & I'm unsure how to proceed.
For the last month or my line (2mbps/Netgear DGN2200) has been plagued by latency spikes during peak times (Friday/Sat night). Roughly 10 sec interval, but irregular.
Today the latency is completely shot. 200-400ms average with occasional short periods of 17ms (normal). The "today" part being interesting in that the router shows the ADSL interface went down 13 hours ago.
Speedtests at ~80% of normal. Kinda weak, but not something I'd freak out about. Browsing OKish - maybe slightly slow.
Tried:
>>Port reset
>>Other ISP (OW/TI)
>>Other computer
>>Router reset
>>Disconnect phone
>>No port filter
>>DNS from custom to auto
>>Blocked everything except ICMP
Phoned Telkom, they reckon both exchange and line looks fine their side.
Line stats
Noted fluctuating Noise margin between 14-16. Fluctuations unusual - usually more stable @ 16 if memory serves.
Latency pattern (telkom.co.za)
Tracerts show the latency is on first hop after router, regardless of ISP.
Everything except latency seems to be at least OK.
So...is this a congested exchange or a line fault?
Evening people
Tried:
>>Port reset
>>Other ISP (OW/TI)
>>Other computer
>>Router reset
>>Disconnect phone
>>No port filter
Line stats
Line Attenuation 29.0 db 18.0 db
Noise Margin 14.4 db 12.0 db
Reply from 196.43.22.222: bytes=32 time=275ms TTL=242
Reply from 196.43.22.222: bytes=32 time=199ms TTL=242
Reply from 196.43.22.222: bytes=32 time=124ms TTL=242
Reply from 196.43.22.222: bytes=32 time=120ms TTL=242
Reply from 196.43.22.222: bytes=32 time=172ms TTL=242
Reply from 196.43.22.222: bytes=32 time=193ms TTL=242
Reply from 196.43.22.222: bytes=32 time=82ms TTL=242
Reply from 196.43.22.222: bytes=32 time=78ms TTL=242
Reply from 196.43.22.222: bytes=32 time=139ms TTL=242
Reply from 196.43.22.222: bytes=32 time=150ms TTL=242
Reply from 196.43.22.222: bytes=32 time=173ms TTL=242
Reply from 196.43.22.222: bytes=32 time=50ms TTL=242
Reply from 196.43.22.222: bytes=32 time=16ms TTL=242 {Normal}
Reply from 196.43.22.222: bytes=32 time=17ms TTL=242 {Normal}
Reply from 196.43.22.222: bytes=32 time=19ms TTL=242 {Normal}
Reply from 196.43.22.222: bytes=32 time=70ms TTL=242
Reply from 196.43.22.222: bytes=32 time=113ms TTL=242
