how does nero work
upup
currently offline
nero is for me the most confusing program.
I dont know which version is which.
you get a 7 essentails, 7 light , 7 ultra. Think there is also a 7 premium.
I search nero but cannot figure out which nero is the bigger better version.
On the forums every one says nero 7 are the better performing one. But there are lots of nero 7 versions.
I like the wave editor and soundbox in nero.
currently uses 7 ultra 7.10. Not very happy with the inferface , confusing for me.
Do any one know of a comparing table.
I use to have roxio 6, the best interface, but then after some windows update it started to malfuntion, then move to nero.
Nero 7 Platinum is still the MOST stable of them all. It does what it was ment to do. I have the 5.1 plugin & so can take a 2.1 avi and convert it to full surround sound DVD by a click of a mouse. This new version just complicate things like Vista did with XP :mad:
Nero is great software (the toys you get), but inCd (which Nero runs in the background) messes up your pc badly.
I use InfraRecorder. It does the job brilliantly.
