How much power does your PC need?
Sure, this applies to all industries, none being exempt from the need for electricity, but ICT-heavy organisations are going to be among the hardest hit, besides the mines and their famously power-hungry smelters, which I suspect will just close down or have their workloads halved.
Electricity price hike doesn't affect the smelters they have long-term contracts that have been in place since the 70s if I recall correctly. In fact I believe their power is supplied at below cost and we are required to subsidise it.
Ummm... how can you write this kind of article and not give typical values and figures??????
Sheesh.
and it's not even our smelters...most are from australia...as per carte blanche
1 Kilowatt hour on average costs a rounded 50c, a mid - high end pc draws 500 Watt, therefore it costs 50c every two hours.
R6 for 24 hours.
R180 a month.
now I may be wrong, but I'm quite certain that these calculations are correct, at 500 Watt, and 50c/KiloWatt from Eskom. I think it's slighly less off peak, and changes according to season.
the first world continues to milk the third, developing, emerging markets :mad:
That wasn't the reason (not in my opinion anyway). Remember when those deals were signed SA had extra capacity. Those deals were designed to get investment into the country despite all the global negative press surrounding the treatment of people of colour in this country. It wasn't about first world countries trying to milk us at all.
At the time those prices were completely acceptable because for the foreseeable future we had ample generating capacity, all we were doing was making the most of what would have been wasted power anyway and at the same time encouraging investment that would not otherwise have occurred. The Nats didn't foresee the mess that Eskom was to become though so now those deals are a little unfavourable to say the least. There is no way out of those deals in the short-term short because the smelters are hardly likely to entertain changing the prices those contracts give them. Dissolving Eskom and privatising electricity generation could potentially be a way to nullify the contracts but that isn't going to happen anytime soon.
R6 for 24 hours.
R180 a month.
Just because you have a 500 Watt power supply does not mean that the machine utilizes that amount of power. I have 2 machines on 24/7 and there's no way they are costing me that much...
Your pc wont draw 500w continuiousousouly (spelling "might" be wrong). You're system might only need 350w of that in total at peak performance, but idle at say 200w.
All figures are just as an example. Easiest is to hook up a volt meter to it (dont do it if you dont know what you're doing).
Remember, hard drives spin down, graphic cards idle ect ect...
Of course, just taking the absolute maximum, for instance a hard disk takes about 8Watt on load, the core i7 processor is around 130Watt (Intel Site)
Sure it's not 500 Watt continiously although better give the maximum cost.
I still think R180 a month at maximum load, if it were to draw 500 Watt continiously, is not that costly.
My notebook is on 24/7 (max 19V 6A) , the only power saving I have on it is the cpu scaling, but I estimate it draws about 50 Watt on average which makes it quite affordable.
Kan ek jou book om te kom "volt-meet" :)
I declock my laptop and my desktop's CPUs and GFX cards when I don't need the power. Win7 runs fine on a declocked 9600M GT, so why waste the power? :) The CPU's also reduce the V-core as the multiplier drops = uses much less power when just browsing the web or doing a download. Laptop on 0.9250V-core as I'm typing this :)
My desktop's PSU is also rated at 80+ efficiency, so less power-wastage. I want a 90% efficiency PSU though :p
Doesn't the screen consume the most electricity? Just switch it of when it is idle.
I also got 2 pc and they are on 24/7 and also online 24/7 and I use 1 LCD screen connected to the 2 pc's and I switch the screen off when I am not at the pc or not at home
What is with these "computer" things they talk about? And those power ratings! Insane... they run not only into double digits but triple digits!!!
Nah, the 2w my Nokia 5800 consumes at peak is enough to enable me to take over the world :p
Sheesh.
Or mentioning sleep/standby.
I do think we'll be seeing a move towards high efficiency PSUs on new purchases though.
R6 for 24 hours.
R180 a month.
Yes, but you have to note that if it's running 24/7 it's most probably not using 500W all the time, as when surfing or just being idle the GPU and CPU are not pulling much power, so probably 150W when idle/surfing and up to 500W gaming.
Someone in our company had to calculate exactly this a few months ago. See below.
Note that it is with the screen of and on-board graphics.
Cost of electricity in Cape Town - http://www.capetown.gov.za/en/electricity/tariffs/Pages/default.aspx
Small Power Users 1 (> 900 kWh per month)
62.33c per KwH
Accodording to http://extreme.outervision.com/PSUEngine a PC with the following specs would use 128W power at 60% load, with a monitor turned of.
• Regular ATX Motherboard
• 1 Physical CPU – Inter Core 2 Duo E6600
• 2 Sticks DDR3 Memory
• Video – Onboard
• 2 x 7200RPM Hard Drives
• 1x DVD-RW Drive
• 1 x PCI NIC
• 1 Addional PCI-Express Card
Thus ,
<u>128W x 24 Hours</u> x R0.62 = R1.90 for a full day
1000
Please note that this figures are ar 60% load. It drops to under 40W when a pc is not in use and just idle, thus
<u>40W x 24 Hours</u> x R0.62 = R0.60 for a full day
1000
