how to graph iozone output using OpenOffice?
SilverNodashi
Johannesburg, South Africa
Hi all,
Can anyone please steer me in the right direction with this one? I've searched the net, but couldn't find a clear answer.
How do I actually generate graphs from iozone, using OpenOffice? Every website I've been to simply mentions that iozone can output an xls file which can be used in MS Excel to generate a 3D graph. But, I can't see how it's actually done. Can anyone please help me with this?
I've run the following command on a CentOS 5.4 server:
iozone -R -l 5 -u 5 -r 1m -s 100m -F /home/f1 /home/f2 /home/f3 /home/f4 /home/f5 | tee -a /tmp/iozone_results.txt &
And then imported the iozone_results.tx file into OpenOffice Calc, but got no idea where to from here?
I would like todo something like this:
http://www.smallnetbuilder.com/imag...tter_than_one/n2100_thecus_1000m_read_big.png
http://oraclue.com/2008/10/03/iozone-filesystem-benchmark-too/
I don't know iozone, but I came across this in the documentation:
Code:
-b filename
   Iozone will create a binary file format file in Excel compatible output of results.
So, try adding a "-b iozone_results.xls" somewhere in there, instead of using "| tee..."
