How to run a Post PPPOE Connection Script in XP
amarjits
Durban - South Africa
Hi,
i want to set some routes on a Windows XP machine (which i am using as a proxy server) after the PPPOE connection link is established.
at the moment i have to do it manually...means after dialing the connection i run this batch file to setup all the routes...
can't we do something like in linux ????
I'm doing something like this in a Python script.
You can use the rasdial command to initiate a connection from a script. Your batch file can dial the connection for you and then set up the routes.
Code:
[c:\]rasdial /?
USAGE:
        rasdial entryname [username [password|*]] [/DOMAIN:domain]
                [/PHONE:phonenumber] [/CALLBACK:callbacknumber]
                [/PHONEBOOK:phonebookfile] [/PREFIXSUFFIX]
        rasdial [entryname] /DISCONNECT
        rasdial
