How to share Wifi connection.
Saltex
Germany
So dunno if this is possible, but anyway, my desktop is connected to the internet via wifi so not with a lan cable! Now I wanna know is it possible for me to share my wifi connection so that I can connect to desktops internet connection via my phone? Or would this require a second adapter.
Why don't you just connect with your phone to the router providing the internet connection to your PC, directly? Going via your PC seems a bit unnecessary?
I meant to say with my Wii U to PC, because I am having major problems with getting the Wii U connected to the router, I did a whole bunch of changes to settings on the router, and eventually got it to connect, but then next day I wanna play again and not wanting to connect again, it seems like I have to restart the router everytime I wanna connect with my Wii U, and the router is quite out of my way and a hassle to get to.
Asus have a few small routers that can create a wifi hot spot from a wifi connection.
WL-330 comes to mind. There are others as well.
http://www.bhphotovideo.com/c/produ...330N_WL_330N_5_in_1_Wireless_N150_Mobile.html
Try this application. It works for Win7/8.
I think it can coexist with your current wifi connection, just give it a try.
It creates a Wifi hotspot on your pc's wifi adaptor. You can even do it from command line, but this makes it just easier to manage.
http://virtualrouter.codeplex.com/
Do you mean to say Nintendo still only support WEP encryption and that it won't play well with WPA2?
Why would they? It's just a glorified Mario Bro's console
It's my first console since a ps1, being mostly a pc gamer I felt like something a bit different, and ya nintendo games are just pure win.
