How to unpartition harddrive
tsume
The Pervy Sage
In the vasts of the internet
Does anyone know how to unpartition or any unpartitioning software I can use. I tried on Windows using the Disk Management tool in the Computer Manager by deleting the partition and then extending the volume, but when I tried this I got a an error saying that "Dynamic disks are not supported by the operating system"
By using the windows xp/vista/ windows 7 or windows 98 CD whatever one you got
But this will delete you information on your hardrive
it will work same with what I said except you choose the external hard drive instead of your windows one
Just make sure you not selecting the wrong hardrive
I've done it with flash disk's and external hardrives before so it works fine
Use EASEUS partition manager, GUI based and user-friendly
Use a linux live disk(ubuntu gparted live, knoppix, etc) boot up, start gparted gui and do it, shouldn't lose anything really...
Unless something unusual happens
Sent from my GT-I9000 using MyBroadband Android App
