Dolby
- Jan 31, 2005
I received a Huawei Q2 Pro (AC1200) mesh kit (triple pack) and - although I'm by no means a WiFi professional - want to give my thoughts on the system from a layman point of view.
I'm going to split this review into PERFORMANCE REVIEW and FEATURES, which I'll upload shortly with photos / setup / app control etc. But in this thread, I'm focusing on the performance aspect only.
Some background :
* I have a 50Mbps / 50Mbps fibre line and a small 80sqm house
* The Calix WiFi N router I was given by MFN didn't even cover my little place
and my furthest Sonoff devices / camera / irrigation outside couldn't even connect to my network
* I managed to get hold of a pack of AirTies 4920 (AC1600) mesh units a few years ago - and really love the WiFi coverage & performance
* Everything that I needed to be covered, could be covered - although I'd always had issues in location #1 and #2 below
* I've been lucky enough to compare the Huawei vs the AirTies - in the same location, similar times of day and everything on (band steering etc)
* I'm using a Huawei M20P for the connection
So, before I installed the Huawei Q2 Pro - I thought I'd first take readings at the 4 locations (above) first to see any differences between it and my AirTies. Note location #4 is pretty challenging as there is actually a another property/tree's in-between - and it's sitting at 35m away. Regardless, I added it to see what happens at the limits of reception :
AIRTIES :
I've also noted my Rainbird irrigation @ RSSI -58Dbi with the AirTies
Location #1 - Single Strength (Excellent) / Linkspeed (87Mbps) / Frequency (5Ghz) - DL : 48.6Mbps and UL : 33.3Mbps
Location #2 - Single Strength (Good) / Linkspeed (6Mbps) / Frequency (5Ghz) - DL : 48.5Mbps and UL : 21.4Mbps
Location #3 - Single Strength (Excellent) / Linkspeed (87Mbps) / Frequency (5Ghz) - DL : 41.4Mbps and UL : 5.79Mbps
Location #4 - Single Strength (Fair) / Linkspeed (6Mbps) / Frequency (5Ghz) - DL : 0.36Mbps and UL : 0.01Mbps
HUAWEI :
I've also noted my Rainbird irrigation @ RSSI -54Dbi with the Huawei
Location #1 - Single Strength (Fair) / Linkspeed (40Mbps) / Frequency (5Ghz) - DL : 48.6Mbps and UL : 48Mbps
Location #2 - Single Strength (Fair) / Linkspeed (117Mbps) / Frequency (5Ghz) - DL : 40.8Mbps and UL : 39..4Mbps
Location #3 - Single Strength (Good) / Linkspeed (175Mbps) / Frequency (5Ghz) - DL : 48.5Mbps and UL : 28.2Mbps
Location #4 - Single Strength (Fair) / Linkspeed (13Mbps) / Frequency (2.4Ghz) - DL : 6Mbps and UL : 2.81Mbps
OBSERVATIONS
* The Huawei seemed to fair much better at location #4 - whereas the AirTies struggled at the fringe of the network! Ths Huawei HANGS onto a signal!
* The Huawei dropped the phone from 5Ghz to 2.4Ghz at location #4 - where the AirTies remained at the 5Ghz frequency
* The Rainbird irrigation continually reported a better signal when using the Huawei (-54 vs -58)
* The AirTies continually reported a better single strength than the Huawei - but this didn't always reflect the results I saw
Some background :
AIRTIES :
HUAWEI :
OBSERVATIONS
