I have a problem with my Opel Corsa
Clivy2mad
I have a 2002 Opel Corsa 1.4 Active with a miss when idling but perfect when you rev the car. I have replaced the spark plugs, the leads and cleaned the idling sensor. Any ideas as to what could be wrong. Pensioner and unemployed doing repairs myself.
I will certainly try that what would be the best way to clean it. Thanks
I also added a bottle of injector cleaner to the tank when i filled up would that help
It is usually the coil, when last was it replaced? Also check for perished and cracked vacuum pipes.
Yip. Coil or injectors, I thought injectors cause the coil problem would still be there at normal throttle not only idle, where injectors often even out at higher revs?
I remember back in the day I had endless problems that led to changing everything incl fuel pump etc by the dealer and problem persisted.
Issue was a fuel pump relay only picked up by an indy. Cost was like 20bucks
Dealer was Williams Hunt in Durban. Blerrie useless bunch.
I made them refund me everything done prior to that and this was prior to CPA
