qscwbt
- Feb 24, 2014
The little database of Corsa issues.
https://mybroadband.co.za/forum/threads/opel-corsa-fuel-supply-problem.402715/#post-22939666
https://mybroadband.co.za/forum/threads/opel-corsa-lite-loss-of-power.524610/
https://mybroadband.co.za/forum/threads/high-idle-after-replace-icv.790913/
https://mybroadband.co.za/forum/thr...-opel-corsa-lite.1007196/page-2#post-22937810
https://mybroadband.co.za/forum/threads/2004-opel-corsa-lite-oil-leak.1001914/
https://mybroadband.co.za/forum/threads/opel-corsa-spare-parts-westrand.997990/
https://mybroadband.co.za/forum/thr...e-sport-idling-problems.995150/#post-22600104
https://mybroadband.co.za/forum/threads/power-steering-eps-failure.925232/page-2#post-22568220
https://mybroadband.co.za/forum/threads/opel-corsa-shocks.969547/
https://mybroadband.co.za/forum/threads/corsa-gear-clutch-problem.961003/
https://mybroadband.co.za/forum/threads/2010-opel-corsa-d-1-4-essentia-car-alarm-not-working.923532/
https://mybroadband.co.za/forum/threads/corsa-lite-a-c-advice-need.908507/
https://mybroadband.co.za/forum/threads/corsa-utility-1-7-alternator.844274/
https://mybroadband.co.za/forum/threads/my-opel-corsa-lite-1-4-2003-model-power-problem.884454/
https://mybroadband.co.za/forum/threads/cant-change-gears-on-corsa-d.870009/
https://mybroadband.co.za/forum/threads/opel-corsa-b-1999-help-to-change-rear-brake-cylinder.857704/
https://mybroadband.co.za/forum/threads/opel-corsa-2004-model.855680/
https://mybroadband.co.za/forum/threads/corsa-1-4-2005-model-not-ideling.854315/
https://mybroadband.co.za/forum/threads/opel-corsa-lite.1010692/
https://mybroadband.co.za/forum/threads/opel-corsa-b-corsa-lite-clutch-pedal-repaired.1019394/
Opel-corsa-lite-cutting-out
Corsa D not starting
https://mybroadband.co.za/forum/threads/corsa-lite-cam-belt-replacement.794655/
https://mybroadband.co.za/forum/threads/opel-corsa-battery-issue.712796/
https://mybroadband.co.za/forum/threads/corsa-utility-1-4-sport-horrible-consumption.1034579/
https://mybroadband.co.za/forum/threads/corsa-utility-1-4-fuel-economy-consumption.222120/
Now for another Corsa Bakkie: Opel Corsa Utility rear break drum stuck
And another missed one here.
Opel Corsa 1.4i Lite bad acceleration and rough idling
And a brand new one.......I have a problem with my Opel Corsa
Problem with Corsa Utility bakkie gear selector
https://mybroadband.co.za/forum/threads/opel-corsa-clutch-problems.1036287/
https://mybroadband.co.za/forum/threads/car-trouble-jerking-misfiring.1041525/
mybroadband.co.za
mybroadband.co.za
mybroadband.co.za
mybroadband.co.za
mybroadband.co.za
Opel PARTS checker https://opel.7zap.com/en/car/s93/
mybroadband.co.za
mybroadband.co.za
Opel Corsa 1.4 Faulty
Hi, I have a 2008 Opel Corsa 1.4. The highest speed it goes is up to 140km/h and the rev will be at 7 already. It started after we replaced the intake valves. The recently started loosing power and it cannot go uphill or even at a slide hill or across a stream. The highest speed now is back to...
Opel Corsa Reverse not fully engaging after replacing clutch cable
Hi guys So I replaced the clutch cable on my corsa Bakkie 1.4 recently and now have the problem of the reverse gear not engaging without grinding the gears. The corsa has a pull tab mechanism to engage reverse and when i try to put it into reverse the gears grind so what I've been doing is...
Opel Corsa Lite over fueling.
. I have a 1999 Opel Corsa Lite 1300. I spend a fortune on spark plugs because the car overfuels. I've taken the car for diagnostics and it shows no errors. Does anynody know what the problem could be?
Need identification on engine code Corsa B UTE
Hi, i have a corsa B ute bakkie the 2003 model, she bent 4 exhaust valves on 28 December :( On disk on engine code it says WC00---- , this is not a valid GM Engine code since i heard they created these in brazil and imported them to South Africa It could be the C14SE or the C14NZ.. need new...
Smoking Opel Corsa D - A14XER
Hello Everyone, I'm driving a 2014 Opel Corsa D, A14XER motor and recently sent the car in for repairs. The car overheated and blew the head gasket. Sent the head to engineers, confirmed, it wasn't bad, nothing warped and bent, replaced values and seals and cleaned it up, didn't need a skimming...
Opel Corsa, crank no start problem
Hi guys! I found this site and it looks pretty awesome let's see if someone can help me with this problem. My Opel Corsa Lite started this morning and I switched it off before it warmed up (to open the boot). I tried starting it again and the engin cranked but it didn't take. It just...
opel corsa lite loss of power and heavy fuel smell
Hi Guys I have a corsa lite 2008 model. Recently is has gotten so bad with power and a heavy fuel smell. Is it possible this could be the Fuel presure Regulator. When i stop. i have to rev all the way to get going and as soon as my rev gage reachers 4000 then the car power will kick in. BUT...
