I need help with wp website problem
Masu
When sharing posts to facebook or pinterest the featured image does not show.
Using this https://developers.facebook.com/tools/debug/
I get this error
caution-solidWarnings That Should Be Fixed
Inferred Property
The 'og:image' property should be explicitly provided, even if a value can be inferred from other tags.
Missing Properties
The following required properties are missing: og:image, og:description, fb:app_id
Google said install jetpack and
Always Use Open Graph with Jetpack
After installing jetpack etc all my images disappeared....I uninstalled both. Now images show on website again but I do not want to fiddle anymore with things I am clueless about in case I really mess something big up.
I have uninstalled most of the plugins.
How can I fix these issues? ie: ' og:image, og:description, fb:app_id OR can someone recommend someone who can assist with fixing these issues without charging and arm and a leg.
NB: I am clueless.
I should be able to help I would have done this for free but as I am REALLY busy this year I can't. Doesn't sound like too big of a problem but you never know. Can you maybe pm me some screenshots?
Hi
I assume you are using WordPress, it happen when you share in Facebook a post it show blank image, something might work for you, I use it myself
Install SEO pluing like All in one SEO, you will notice on each page / post when you install it at the top new section where you can select the image for social sharing, it work for me
need help https://devopsbiz.co.za
