Donovan
iBurst users - I would greatly appreciate it if you could do the following:
1. Uncapped Speed Test
Please run the test at www.bandwidthplace.com while you are UNcapped (preferably when you're actually connected at 1024kbps).
2. Capped speed test
Please run the test at www.bandwidthplace.com while you are CAPPED (ie, running at 64kbps).
The reason I ask you to do this is because I am considering signing up for iBurst. I've searched the forums and it's quite difficult to find recent speed tests on iBurst.
Thank you very much!
Also: if you were previously a MyWireless customer, please can you comment on whether iBurst is an improvement or not over Sentech's cr appy offering.
