iCal Problem
soundbase
My hard drive crashed on my Macbook. I had 10.4 on it. Luckily I had a backup of my data.
I have installed 10.6 on the new hard drive. I am having some issues trying to pull my data back to iCal. On 10.4 the data used to sit here ~/Library/Application Support/iCal/Sources.
I see now on 10.6 the iCal Data sits now ~/Library/Calendars/
I tried copying the Data from Sources to Calendars. But when I launch iCal it does to pick up the added data.
Does anyone know how to import the previous iCal data back.
I wasn't fortunate enough to do a database backup through iCal, so I only have the data in the 10.4 iCal/Sources folder.
If anyone can help, it will be much appreciated
I think you have to copy it over to a machine with Tiger, then re-export it. Ugh what a schlep.
