I only switch mine on (in the absence of actual fog) when inconsiderate drivers come up behind me with their front fogs or high-beams on.
When I smoked I would blast my washer fluid and empty the ashtray out the window - that generally made my point too.lol, me too. but i think the gesture sometimes (read mostly) pass over the idiot-driver's head
I usually have mine adjusted in the middle (which is the default setting) and only adjust them higher if travelling at a speed on a dark national road. If someone had theirs set to unusually high in normal conditions, I just flash them, though I don't think they realise what the problem is.
Quick q, please don't say "they're for parking"...could someone please explain to me what park lights are actually for?
They're so that your car is visible in low visibility areas when parked. Stopped on the side of dark roads, for example. Because the globes are low wattage, they don't drain the battery like leaving headlights on would.
So true. You cant even begin to imagine how many people I have heard say "but it looks cool"It's all about some kind of status or image that they think they get from doing it.
Only if they are set up wrong. One 50W bulb cant shine brighter than another 50W bulb of the same kindToyota's head lights are also too bright, even if they are not on bright...
Not too bright, just not adjusted correctly in that it's shining upwards, instead of slightly downwards.Toyota's head lights are also too bright, even if they are not on bright...
Hehehe, yeah, the like sitting very low and have their arms hanging out the window. I just wish somthing would crash into their door.Usually done by the "put my seat as far back as possible and lean forward anyway" brigade
God bless Mercedes with their dodgy vacuum operating headlight height adjustmentNot too bright, just not adjusted correctly in that it's shining upwards, instead of slightly downwards.
I was uploading some photo's and found these today.. I had actually forgotten about them
On audi's and golf's, the light switch is a knob that you pull out once for front fogs and twice for rear fogs.
