If Skype is open WAMP does not work
Thor
Bellville
Just installed skype (I hate it, filled with ads and slow as hell)
What causes this Wamp interference?
I have to either
Run Wamp services before Skype
or
Quit Skype -> Run WAMP -> Run Skype
I suppose some port conflict?
has to be port conflicts.. or at least thats the first thing that jumps to mind.. the wamp logs should state this though..
just move to a vm environment for the wamp services though..
In Skype:
Tools -> Options -> Advanced -> Connection
Uncheck: "Use port 80 and 443 for additional incoming connections"
Skype uses port 443 and 80. A rather perplexing decision.
In Skype:
God.
That worked. Naas
However will convert all my skype people to discord
You need to open Skype, Tools > options
Then click on Advanced in the left menu and then Connection.
Skype uses port 80 by default and WAMP uses the same. So change Skype's port number to something else and restart. And then also restart WAMP.
That should work!
That should work!
I have done so, thanks kind sir.
